tketke2002
Member level 1
Input impedance in HFFS
Anyone know why the input impedance of an antenna changes when in case of a lumped port the plane used for the lumped port is changed in dimensions?
I am simulating a planar antenna with a slot that is fed with alumped port of 1x0.5 mm (plane). If I change the dimensions to 1x0.1 or other than the input impedance of the antenna is changed considerably...
Does anyone an explanation...
tony
tony
