Why if I interchange terminals in comparator I am not seeing the same voltage ?
bsrivastava
Member level 2
Member level 2
In op-amp V+ and V- are not interchangeable, but in comparator Vin and Vref are.
(Vin is DC sweep)
Is this correct?
If so, if I am interchanging the terminals in comparator, and I am not seeing the same voltage characterstics, what is the reason.? Is this the result of offset?
-Bharat
Re: op-amp vs comparator
If you switch the signs around for comparator, you switch the output of the waveform. It is fliped.
yes, it is the result of offset.
it's the result of offset and asymmetrical of the circuit.
i don't understand the effect of offset and asymmetrical to the ciruit
can you tell me some more explanations? thank you!
When u change the terminals , u wont the get same output as the symmetricity of the comparator is lost
