Why I got PSPICE error message as"Less than 2 connections at node 1"
ermai
Member level 1
Member level 1
Why did I get a PSpice error message as"Less than 2 connections at node 1"
Below is my description for a simple and easy circuit(just series of two resistor and one source),and I use PSpice Stduent.
Vin 1 0 DC
Ra 1 2 1k
Rb 2 0 1k
.PROBE
but it make error in PSPICE as below
**** 07/29/12 21:21:12 *********** Evaluation PSpice (Nov 1999) **************
Vin 1 0 DC 1V
**** CIRCUIT DESCRIPTION
Ra 1 2 1k
Rb 2 0 1k
.PROBE
ERROR -- Less than 2 connections at node 1
I am puzzled what the error "Less than 2 connections at node 1" means,I have connected all node ,none is leave.
I am puzzled by what you actually used. The earlier part of your post shows
Vin 1 0 DC
Which is missing a voltage e.g.
Vin 1 0 DC 5
But later in your post you show
Vin 1 0 DC 1V
What have you actually used?
Keith
Re: Why I got PSPICE error message as"Less than 2 connections at node 1"
Vin 1 0 DC
Vin 1 0 DC 5
Vin 1 0 DC 1V
Keith
I used Vin 1 0 DC 1V ,thanks.
The description is :
Vin 1 0 DC 1V
Ra 1 2 1k
Rb 2 0 1k
.PROBE
The simulating result is
**** 07/30/12 07:07:46 *********** Evaluation PSpice (Nov 1999) **************
Vin 1 0 DC 1V
Ra 1 2 1k
Rb 2 0 1k
.PROBE
I also write another text file for test,which is as below:
Vin 1 0 DC 1V
R1 1 0 1k
.PROBE
It also exhibits the same error message " Less than 2 connections at node 1 "
The first line is being ignored as a title statement - the simulation should start on the second line. Add any text on the first line as a title.
Keith
Keith
It worked.Thanks.
Hello to every body, i am new here and i need your help. i have circuit designed in OrCAD capture cis lite. i am getting ERROR(ORPSIM-15141): Less than 2 connections at node N02458. how i can get ride of this problem.
**** 04/18/14 11:55:30 ****** PSpice Lite (October 2012) ****** ID# 10813 ****
** Profile: "SCHEMATIC1-TEST_1" [ C:\project\orCAD Simulations\awake_NMOS_1-PSpiceFiles\SCHEMATIC1\TEST_1.sim ]
** Creating circuit file "TEST_1.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of C:\Users\Bilal\AppData\Roaming\SPB_16.6\cdssetup\OrCAD_PSpice/16.6.0/PSpice.ini file:
.lib "nomd.lib"
*Analysis directives:
.TRAN 0 10ms 0 1ms
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source AWAKE_NMOS_1
C_C1 N00948 N00982 0.01u TC=0,0
C_C2 0 N00281 1u TC=0,0
R_R1 N00948 N00388 2.5MEG TC=0,0
R_R2 0 N00281 40MEG TC=0,0
V_V1 N00388 0 3.3Vdc
D_D1 N00982 N00281 D1N4002
D_D2 0 N00982 D1N4002
V_V2 N00948 0 5Vdc
R_R5 N02458 N00388 1k
**** RESUMING TEST_1.cir ****
.END
Thanks in advance.
regards
Bilal Ahmad
