Jenifer_gao
Member level 1
Hi:
I was using Pspice 9 student version to learn some simulation. I input a transistor from the breakout library, and then to edit the model file. It's fine when I worked with Schematics, and I can modify the model file as I like. But when I worked with Capture, I find I can't modify the model. Every time when I checked the simulation result, I found it always use the same model file associated with MbreakN transistor. My modification doesn't work. If any experienced person can give me a hint to make the part to link to the new model file.
Thanks,
Thanks,
