Why I can use Linux ver. of Modelsim with Windows license?
W
webt
Newbie level 1
modelsim problem
why I can't use linux version with a windows license.
Does the license file really depends on os platform?
Do you use it as a license server?
Re: modelsim problem
The license is not OS dependent. Be sure that you are using the ModelSim release version on both platforms and the same hostid(node-locked or license server).
the linux version has one more feature called winmain which is not used in windows plateform.
hock
it's depend which feature you got. some one is depend platform & some one not.
good luck.
Maybe you should check the version of modelsim.
I wonder that the old version for linux didn't support modelsim deamon. It supported metor deamon only.
The daemon needed is mgcld.
It support modelsim deamon after the version 5.4.
You ned a license server Updated and new version of vendor daemon,
Your license is the same for windows linux or solaris, the difference is the vendor daemon and flexlm
Gianni
