Why I can see data on floppy in Linux ?
E-goe
Member level 5
Member level 5
Reading file from floppy
Hi
First of all I'm a Linux newbie
I have 2 OS running on my PC ( default one is WinXP en the other is RedHat Linux). As for now I'm only able to connect to the internet via XP ( not yet installed Samba).
So when I download a file from the internet, for example Spice.tar and copy the file to a floppy and restart my PC and log in in RedHat I'm not able to see the file I copied , in windows on the floppy under Linux????
Is this normal? What am I doing wrong???
Greetz E-goe
Re: Reading file from floppy
I don't know if redhat uses automounter so, Since Linux Is quite responsible on what he is doing, he will let you decide when you are going to see what is in a floppy(or any block device), so you will have to
MOUNT IT.
Sou will have permission to mount the floppy, check it at the /etc/fstab, also check there the mounting point( think in redhat the lines below will work without doing a thing)
from shell :
$ mount /mnt/floppy/
$ ls /mnt/floppy/
when done
$umount /mnt/floppy
Remember to always umont the disk!!
First, you do not need a floppy to copy file from XP to Linux.
Linux can view FAT32 filesystem well.
You need to mount your FAT32 partition under Linux, as example:
mount -t vfat /dev/hda1 /mnt
this means: mount vfat filesystem (win32) from 1st partition of first hard drive to directory /mnt of linux.
Now, you will go to /mnt and find all your C:\ disk there...
to unmount it and free directory use:
umount /mnt
or
umount /dev/hda1
to mount floppy you can use:
mount /dev/fd0 /mnt
and your floppy will be found in directory /mnt
And pay attention, that all these commands you need to enter under "root" account.
Just create a FAT32 partition (if you don't have one) an use it as a data exchange buffer.
