Why I can make modify cds.lib in Cadence on RedHat 7.3?
cetc1525
Full Member level 3
Full Member level 3
help me,please!
I setup C@dence in the redhat7.3.Now, I can run icfb,but I can't make a liberay in it. It said that it can't modify cds.lib!
How can I do?
I run lmstat -a -c license.dat , it list a report of soft commandand after the command it say that uncounting,no users.
where does I don't modify?
by the way,I modified my environment in the .bashrc.
Re: help me,please!
I hope your problem has been solved. If not, i guess you have to do as follows:
You should make a c-shell user acount and do what you want there. Don't forget not to login as root. It may cause a permanent crash of linux.
Regards,
KH
Re: help me,please!
create your own library in a new directory outside the tool directory, the one you try to create in is write protected
