Why high gain in opamp ?
coolstuff07
Please answer my question.
Bye
Read more details here
http://focus.ti.com/lit/an/sboa092a/sboa092a.pdf
http://www.dei.unipd.it/~pel/Elettronica_Analogica/understanding_OPAMP_specs.pdf
take the buffer as an example. the gain with feedback is =Ao/(1+AoB).since B=1 we have Af=Ao/(1+Ao), now if Ao -->inf Af-->1 ,hence we require high gain in opamp to reduce the dependence of closed loop gain on the open loop gain.The gain of an ideal opamp must depend only on its feedback elements,that's achieved only through a high gain.
Is it some thing related to virtual ground.
Bye
in order to get high open loop gain in a opamp negative feedback system.
b/r
first, it depends on the application and not always high gain is desirable. In LNAs, we concentrate on the noise first.
An amplifier is supposed to amplify, the higher the gain, the more the amplification
The higher the gain , the opam is more close to ideal model.
If one input of your amplifier is connected to virture ground, then, the higher the gain, the other input is closer to virture ground.
op-amp is a device which could work both on dc as well as ac.its because it draws no currrent as well as its characteristics like virtual ground,high internal impedance and low output impedance.that it offers such a large gain to voltages specified by its Vcc.
sometimes the high gain comes from the request of linearity
You'd better learn something about feedback theory to full understand it!
