why "ground" is not affected by noise through cap
rom0011
Newbie level 5
Newbie level 5
hi all :
why "ground" or "power" are not affected by noise through capacitor?
For example, a common source nmos input circuit which source is connected
to ground,and its gate is connected a capacitor to ground.
When its gate has a noise voltage spike,because i think capacitor provide a low impedence path from gate to ground at high frequency,why ground is not affected by this noise spike?
You see, the capacitor has some low admittance at the interesting frequencies, buut your GND-line or bbetetr, Plane has more lower impedance at the same frequecies, so its practically not affectedby your noise/spikes. In all cases its same affected, but it will attenuated/(practically shorted) betwwen Cadmittance:Rgnd-plane(if GND enough good "working" is)...
K.
It is affected, if "ground" is not ideally stiff. Or if your
reference ground, is not the "ground" where the cap returns.
An on-chip "ground" could have nanohenries and ohms between
it and the board / module ground plane. Whether this matters,
depends on what "ground" the circuitry before and after it
see as their reference point.
