why for electrec mic usually 2.2K is used?
madrose
Newbie level 2
Newbie level 2
Electrec Mic
Can anyone tell me why for electrec mic usually 2.2K is used? What is the factor that determine the value of the resistor?
Thanks...
Electrec Mic
The mic contains a FET. Therefore a resistor needed to connecting VCC.
Assuming mic is short, you may select resistor for 1mA current.
For example: If you want to connect to 12V, you can use 12k. And 1.5k for 1.5V :)
Re: Electrec Mic
So the resistor is solely for powering the mic and has no effect on the output?
Thanks for the reply...
