why does this happen in hfss?
pollop
Member level 1
Member level 1
i have simulated a loop but i only get half the radiation pattern. can anyone explain this ?
thanks
Whats the specs are you giving for creation of infinite sphere. Use default settings. and then try.
Habeeb.
    pollop
hi habeebhabz,
i chose infinite sphere in far field set up, is this what you mean? I havnt changed any settings
thanks
you need to change the infinite spear set up so that it read 360 in for both phi and theta. default is 180 for phi.
ghb
Probelm solved many thanks
