Why does HV9860 LED driver have to use DCM?
T
treez
On page 1 of the HV9860 datasheet it says that the HV9860 is for DCM .
Why is it only for DCM?
Surely it can be used with CCM also? (especially if the duty cycle was <0.5 as then no slope compensation is needed)
HV9860 DATASHEET
It's possible the IC needs to see coil current go to zero during each cycle. Particularly in flyback operation. A flyback has no current in the primary during switch-Off.
If it were in CCM, then coil current would never go to zero.
Reactions: treez
    T
here some of thing which is only useful in some products
if you have any problem regarding your cell phone and there network then you can ask here , we have lots of solution for it like if you lost your bettry during the trevlling then what you do , for this we have mobile power bank which is very useful in travelling time it charge your bettry very fast and provide you a full bettry it is portable device and easy to use there are very veriaty for this
Reactions: treez
    T
