T
treez
Hello,
A lighting designer showed me an offline LED luminaire that he designed.
It comprised 224 LEDs altogether, in 28 paralleled strings of 8_LEDs_in_series.
It comprised four LED PCBs, and each LED PCB contained 56 LEDs (obviously in 7 paralleled strings of 8_LEDs_in_series)
This 224 LED “bank” was supplied by a 230VAC input, 2.8Amp output, Offline Switch Mode Power Supply, and since the LED strings were only eight LEDs long, the maximum output voltage was just 32V.
The designer told me that since the maximum output voltage Of the offline 2.8Amps power supply was just 32V, then the enclosure for this LED luminaire could be made very cheaply (since no high voltages were present that had to be sealed safely away from prying fingers etc.)
If I had been the designer of that luminaire, I would have implemented it as four strings of 56_LEDs_in_series. I would have a high voltage, buck converter to supply each of the four LED strings from the PFC output rail (390V). (so four buck converters in total, one on each of the four LED PCBs.)
However, my solution would have meant having the 390V PFC output voltage on those LED PCBs. –Would this high voltage have meant that the luminaire enclosure would have necessarily been more expensive to make for my design, compared to the low voltage (32V maximum) design?
