djsfantasi
I had a circuit developed and tested successfully. The circuit board actually had two circuits - an audio amplifier and an audio envelope follower - on it.
The audio envelope follower stopped working.
I did mount it in an enclosure.
The amplifier still works - so doubt if its a power problem.
Visual inspection of the board does not show any bad solder joints nor broken traces. It was a commercially prepared board (hence I don't think its a bad trace problem.)
Everything except the basic circuit has been disconnected, to eliminate any related issues.
What else can I do to check it out? Check resistors/trim pots with my meter... (in circuit?)... Check diode for function (in circuit?)... Replace Op Amp...
Any other ideas? (The circuit in question can be seen in my album)
