Why do we need large L for mismatch?
modern_analog
Newbie level 5
Newbie level 5
L effect on mismatch
This might sound very basic but here goes
The mismatch depends on WL, or more accurately 1/sqrt(WL). Then why do we need large L. It seems we can get away with small L and large W.
Re: L effect on mismatch
The problem is that if you have a large W you will have a large parasitic capacitance to substrate. At the same time with a lower L the output resistance will be lower. Also a high L reduce the fliker noise.
Bastos
Lower L tends to have problem in circuit realibility!
If you are using 0.5um technology...
Try to have bigeer L such as 2@3 times higher that 0.5um
:D
1/sqrt(WL) is the mismatch of Vt. If your L is too small, then short channel effect will play a significant role. The Ids will largely depend on Vds.
L affect several parameters for a transistor,you must trade off to chose a good one
u can increase your L, but keeping W/L = constant .
it will be beneficial to your matching & low noise.(eg, noise which comes from substrate)
