chicken_feet
Member level 4
Hi all, I would like ask why do we need an AC cap between the Live and Neutral?
In addition to that, why do we need the 51 Ohm resistor?
My final question is this, when i connect both end of the oscilloscope to the ac live and neutral, one of the 51 Ohm resistor will blow up. I do not understand why. I experimented it twice, and the same result happens. Prior to connecting the probe, the circuitry is running fine. The probe itself is ok in my opinion, we use it to measure direct 240Vac and everything is fine. So where do we make the mistake?
Thks.
Rgds,
chicken_feet
Thks.
Rgds,
chicken_feet
+---------------Resistor 51 Ohm------+--------------------+----
240Vac 0.01uF Full Bridge Rectifier
