karken
Newbie level 2
I have been trying to learn about how NPN BJT's work and I cant seam to understand a few things.
I have attached a diagram of my setup
Vcc = 12v
Vb = 5v
R1 (Collector resistor) 3.935K
R2 (Emitter resistor) 2.94K
I understand that the Ve (Emitter voltage) will be .6v less than Vb (Base voltage). What I dont understand is why. When the transistor is switched on why is Vcc not felt at Vb. It is baffling to me because the current that flows through the collector (Ic) is approximately Ie (emitter current). Ie is completely determined by R2 and Vb.
Ie = (Vb - .6v)/R2 = (5v - .6v)/2.94K = 1.5mA
How is this possible? Once the transistor is on should it not just act like a tiny resistor (the transresistance) and Ve feel the voltage from both Vcc and Vb. I know this is not true but I am struggling to figur out why.
Vcc = 12v
Vb = 5v
