I dont know if this is feasible. What I am tempted to do, since the rate I can plot a graph is slower than the rate the incoming signal is read.
If I know the beginning of every incoming signal let say this point is indicated by a count=0, everytime I detect count=0, I know it is the beginning of each incoming signal, I keep track of how many cycles, let say, I only want to plot the graph every 10 cycles of the incoming signals, I plot cycle no.1, skip 10 cycles, plot cycle no. 11, skip cycle no.12 to 20, next plot cycle no. 21 etc ...in other words, it means I will lose some cycles in between which I am okay with this.
1. Do you think this method make any sense?
2. Do I still need buffering in this case?
3. How do I know how many cycles I need to skip? I assume it would depend on the incoming signal rate (50 Hz) and plot/receive rate (say 8 Hz), But I am not entirely clear about how to calculate...
The incoming signal (50 Hz) is from fpga vhdl, NIos system can read at 50 Mhz, but serial port receive rate or Matlab plot rate is 8 Hz.
Appreciate any input...thank you
