userx51
Junior Member level 2
Some times when reading values from mcu using c program through the serial interface, old values shows up instead. Have to try several times till the new value shows up. why is that?.:?:
can u explain it briefly?whats your exact problem? is Problem happened in software or hardware?Some times when reading values from mcu using c program through the serial interface, old values shows up instead. Have to try several times till the new value shows up. why is that?.:?:
