FreshmanNewbie
Advanced Member level 1
I've a question with the ethernet phy connection to the rj45 connector.
Usually, with either discrete or integrated magnetics, either with Voltage mode PHY or current mode PHY, what is the purpose of the center tap of the magnetics.
In someplaces, with voltage mode PHYs, the centre tap is connected to the ground via a capacitor.
In current mode PHYs, the centre taps are pulled to Vcc via a termination resistor and connected to ground via a capacitor.
I want to understand the current/voltage flow across the magnetics and how does the capacitor on the centre tap is helpful for this? What happens if I don't have the capacitor on the centre tap?
