grizedale
Advanced Member level 3
We have a 15W xenon flash tube (in a flash lamp) which has two diodes in series with it.
The 5W version does not have diodes in series with the xenon tube, so why does the 15W version?
The xenon tube is connected across a 250V capacitor.
One diode (S3G type silicon diode) is connected from the cathode of the tube to the negative terminal of the capacitor. (obviously: cathode of diode to negative termial of capacitor.)
The other diode (again: S3G type silicon diode) is connected from the anode of the tube to the positive terminal of the capacitor (obviosuly: diode anode to capacitor positive terminal)
Why have the designers added these diodes?
The 5W version does not have these diodes.
The only thing i can think is that the stray inductance of the connections to the xenon tube may be causing oscillations and sending the current the wrong way in the tube which would damage it?
