Why diodes are square law detectors?
bouchy
Full Member level 1
USA
Can you please explain to me why diodes are square law detectors?
Thanks
Bouchy
Re: square law detector
The current through a diode is given as:
I = Io (exp(q Vd/kT) - 1)
where Vd is the forward bias voltage drop on the diode. If the 1 is ignored (which can be done for even small Vd's at room temperature) and the exp term expanded in a series of powers of Vd, then the diode curve can be approximated reasonably by an expression consisting of terms upto the square of Vd. So this square law expression represents th diode current. Now when Vd is a modulated signal, this square term would produce the sum and difference of the carrier and the signal frequencies. The carrier can be filtered out giving the signal.
Thus since we use the square term explicitly to detect a signal, the diode is sometimes called the square law detector.
    bouchy
Thanks aryajurs,
I am a bit confuse about this sentence
"Now when Vd is a modulated signal, this square term would produce the sum and difference of the carrier and the signal frequencies "
could you please elaborate.
Thanks
Bouchy
Suppose the Vd across the diode consists of the sum of a AM modulated signal and a frequency same as the carrier, due to the square term the current will have harmonics and intermodulation products, one of which will be the demodulated AM signal.
    bouchy
IT is evident from voltage-current characteristics . it is not a st.line but a parabolic nature.the eqn of parabola is a second degree eqn.similarly for this also.
    bouchy
