why diode didn't block 12mV?
EDA_hg81
Advanced Member level 2
The attachment is my simulation figure.
The question is when the Vss is 3.3V the voltage at “in2” node is 12mV, but why voltage at "out" node is 12mV too?
I think diode is going to block this 12mV and voltage at “out” node should be 0V.
So many thinks for any ideas.
[/i]
Just a guess:
With no load across the output, no current can flow so no voltage can be dropped.
Try adding a high value resistor (1MΩ) from the output to ground and see what happens.
Brian.
    EDA_hg81
it is working now. the output is 420uV when Vss is 3.3V.
Thank you so much.
If i replaced 1n4005 diode with in4148, I got the follow messange:
"breakdown current increased to 3.86635E-10 to resolve incompatability with specified saturation current"
what is the reason for this?
Thanks
That's a simulator complaint, your current in breakdown
can't possibly be less than your reverse saturation current
and it's just informing you that it doesn't like insane model
card inputs.
    EDA_hg81
