Why data lines of USB interface are named minus and plus?
j_caesar
Newbie level 5
Newbie level 5
USB interface
why data lines of usb interface named minus and plus?
thanks
Re: USB interface
USB is a differential signal therefore + and -.
/Froggy
USB interface
Do some one know how to design the USB interface with microcontroller unit.Thanks
Re: USB interface
joshln,
search this forum.
this subject was here a couple of days ago..
USB interface
Some ICs have integrated USB interface and microcontroller. For example:
TUSB3210
Universal Serial Bus General Purpose Device Controller
USB + 8052 Microcontroller
Re: USB interface
Hi All,
USB standards specify a HOST interface and a DEVICE. Usually DEVICE functionality can be easily embedded in small microprocessor while HOST functionality are usually found on 32 bit microprocessor.
FDTI and Silicon labs offers USB to RS232 bridges that can be easily used to connect an RS232 based device to USB host.
Re: USB interface
You have D+ and D- on the USB because you can achieve a better data transmition using + and - voltages. Thsi way the parasite data is less as on a normal D+ serial comunication.
Re: USB interface
http://www.cesko.host.sk/IgorPlugUSB/IgorPlug-USB%20(AVR)_eng.htm
Re: USB interface
The best solution is to use FT245BM or FT232BM chip (www.ftdichip.com). It offers a free driver (*.sys and *.dll file) and can be controlled under Delphi, C++, or any other programming language. These chips can be interfaced to any minctrocontroller. You don't have to know nothing about USB to use the chips... (apart from a few very basic things). You can connect EEPROM to the chips to write your own device name which will be displayed when you first connect your device to PC.
Re: USB interface
FT2232 (http://www.ftdichip.com/) is a extensive solution to interface almost everything with USB. On the net there are universal boards (**broken link removed**) that can be a good start for every application.
Re: USB interface
USB-to-PIC Interface by John Waller .
check out this article in EPE MAGAZINE, April 2004 issue .
Regards .
