subrata_m
Hi All,
I am new to this forum . Can anyone explain the following
doubt which is killing me :grin:
In Razavi book just before starting the explanation about source follower stage it is stated that ,
"To achieve a high voltage gain with limited power supply voltage, the load impedance should be as large as possible .If such a stage is to drive a low-impedance load , then a "buffer" must be placed after the amplifier so as to drive the load with negligible loss of the signal level".
My question is if the "CS stage act as a trans conductance amplifier ,
then why it can not drive a low impedance load" .
In the above diagram of CS stage with a load RL,
Even if output impedance is high which is here approximately RD , I can not understand why the CS stage can not drive a low impedance load .
My understanding is that high output impedance here will be able to draw more current , which will give better driving capability .
