maintain duty-cycle.
Why inverters on the Clock Tree maintain Duty Cycle and the regular buffers don't?
Did you mean "half the number of transistors"?you can drive the signal to the same distance with almost half the number of cells.
Clock buffers and clock inverters are usually built to maintain uniform duty cycle. The main difference is in the area where buffer uses a higher area to drive a signal to certain distance before it has to be rebuffered. If inverters are used , you can drive the signal to the same distance with almost half the number of cells.
