I am sure you knowthe_risk_master said:Is there an m c² compiler? If there is, can you give me links about this?
jhbbunch said:I believe we're still light years away from an mc² compiler.
Well you are almost right .... but there is light at the end of the tunnel.
With the repeatability question regarding the uncertainty principle being unresolved at present - in short -
This means that the mc² compiler© is unable to produce the same object twice from the same source code.
This as you might imagine has caused me more than a few problems in my target application.
The Vendor assures me they are working on a regressive convergent version of the mc² compiler©, named 'Einstein',
that given time will produce a useable object.
However they have not set any time scale on this development.
Polymath
