why bigger VDS introduces bigger rout (small signal)?
wwwww12345
Member level 1
Member level 1
For a first order approximation, rout has no relation about VDS. Anyone can tell me?thanks!
The thing with first order approximation (as with any kind of approximation) is to what extent is it justifiable. Traditionally, MOSFET output resistance was seen as constant and VDS independent (to the first order approximation). In modern sub-micron processes one can not neglect second-order effects anymore, that is why Rout (or Rds) is DEFINITELY DEPENDANT on Vds.
o , I got it ! We can differentiate ids to VDS, then the problem solved.
Well, differentiation would solve the problem if you had a function to differentiate. Don't forget that the expression for transistor current is only an approximate one, that doesn't describe all effects.
What actually happens is following:
1. For smaller Vds, as you increase Vds, rout increases due to the CHANNEL LENGTH MODULATION
2. In short-channel devices, as you increase Vds further, there is an additional effect called DRAIN-INDUCED BARRIER LOWERING which reduces threshold voltage and increases the current, thus effectively canceling the effect 1. In this area of Vds, rout is relatively constant and independent from Vds.
3. As you further increase Vds, IMPACT IONIZATION near the drain produces large current, lowering the output impedance.
Hope I could help
Djordje
