newbie_hs
Full Member level 2
When one looks at common mode chokes for USB 2.0 applications choke manufacturers always recommend CMC with a common mode impedance of 90 ohms @ 100 MHz.
Example
How does this relate to
Example
- USB 2.0 differential impedance of 90 ohms (& 45 ohm single ended impedance)
- the "Hi-Speed" data rate of 480 MBit/s (respectively a frequency of 240 MHz)
- an approximate USB 2.0 bandwidth of ~1200 MHz (5 x 240 MHz)
