Why and how to use the transfer function?
Re: why transfer function?
Hi Dear zhi_yi!
It helps you decide the output of the system for every inputs. It helps you decide if the system is stable or not. It helps you finds out the resonance frequencies of the system. It helps you optimize the system. It helps you... .
Thanks!
You are misinterpreting what I say ... I am saying that impedance IS a transfer function! I am just saying that you should not use output/input to describe the transfer function because it is misleading when applied to impedance since both signals are at the same port. Notice I said that impedance is a "ratio" which all transfer functions are.
Best regards,
Vahe
in instrumentation side the word transfer function is used, in mechanical the word efficiency is used and in electronics side the word gain is used. all above gives just the ratio of output to input with some basic process. the main application of above these are just to determine system behiaviour with all possible inputs
By the basic mean We r giving some input to the system and getting some output but there is some loss inside the system or what ever may be that means we are cheking how much of input is being transferred to the output of the system??? thats why the name TRANSFER FUNCTION. hope it ll help u .
In control engineering and control theory the transfer function is derived using the Laplace transform.
The transfer function was the primary tool used in classical control engineering. However, it has proven to be unwieldy for the analysis of multiple-input multiple-output (MIMO) systems, and has been largely supplanted by state space representations for such systems. In spite of this, a transfer matrix can be always obtained for any linear system, in order to analyze its dynamics and other properties: each element of a transfer matrix is a transfer function relating a particular input variable to an output variable.
OK.
IT tells about how the input is changed to putput
transfer function is the laplace transform of the impulse response. the impulse response of the system is an important issue in analysis phase.
to know the behavious of a system under zero initial conditions
the "function" describe the relationship between inputs and output.
best regards
zhi_yi said:
in control engineering, we learn about transfer function, what is the "function" of the transfer function?
thanks..
the transfer function represents the system in a compact form. all the properties of the system can be understood if one analyse the transsfer function well, for example the stability of the system can be understood from it's pole locations, the time domain behavior can be obtained from the inverse laplcae transform and so on. the function maps the input to the output and hence the name transfer function is given.
