Why an C program .exe cannot get output
hednast
Hello. I have a problem. When I compile in a turbo C compiler I can get the result that I want. But after I compile that project file into an exe and then run that exe, I don't get the results I want anymore. Why is there a difference between the project file and the compiled exe.
Please asists. Thank you.
That's not much information to go on.
I would guess that your project file has configuration settings that are different from Turbo C's default project settings.
Hi
C has two outputs: stdout and stderr
void fprintf(stdout, "...", ...);
void fprintf(stderr, "...", ...);
in most systems stdout is obviously stderr but in some prohramming styles these tow may differ.
you may check it in linux(unix systems) with something like 2>&1 , ...
you may check it in windows with something like
myprog.exe [myparameter ....] > results.txt
please redo these check and approaches and let us know the status.
tnx
Hai.....sorry i am a little confuse with the replies given.........The source code is as below.........
#include <stdio.h>
#include <dos.h>
int main()
int i;
unsigned char far* scrn = (unsigned char far*) 0xb0008000;
FILE *fp = fopen("c:\\text.txt","w");
for(i=0;i<6900;i+=2)
fputc(*(scrn+i),fp);
fclose(fp);
return 0;
When I press Alt+F9, I get the text.txt with the information on the dos screen. Now I have tested. If I open the dos prompt and straight away type the exe Eg: C:\Scrncap.exe, I won't get the output in the c:\text.txt. The file exist but contains nothing inside. But if I open the turbo C compiler, then close it back again. And then type the exe Eg: C:\scrncap.exe, I get the output of the dos screen in the c:\text.txt. This is the part I really don't understand. Why in a newly open dos prompt I cannot capture the text in the c:\text.txt?
Added after 2 hours 50 minutes:
Hai. Thanks for the helps I receive. I found out my problem. My pc is using Win2K. Therefore I can get the result when I do the compilation in Turbo C compiler. But on the plain dos prompt I cannot get the result. I tested on a Win98 machine and it worked well. Extreme good. Therefore I would conclude that the ancient compiler is not compatible with Win2K onwards.
Problem Solved.
Turbo C can not bypass HAL(hardware Abstrection Layer) used in PC.
you will have to use a windows 2000 compitible compiler and use MFC.
no in out instruction can be used in NT environment.
hock
