jerryzhao
Full Member level 3
I design a linear battery charger.
There is a current overshoot when CC(constant current) to CV(constant voltage) mode transition.
The charger structure reference the LTC4062's datasheet. the CC amp and CV amp share one current shink.
When I test the charger, I find the current overshoot. but simulate cann't find this issue.
anyone know root cause of this issue.
I design the max charge current about 1.5A.
I test find. There is an overshoot when charge current larger than 1.2A.
Charger have not overshoot when charger current equal and less than 1.1A
I analyze the test result, I find the current mirror loop cann't follow this I overshoot.
I design the charger:
current loop: gain 60db, bandwidth about 200K,
CCloop: gain 70db bandwidth about 20K
CVloop: gain 70db bandwidth about 10K (ESR of battery and cap of battery, will zero and pole cancel)
When Vbat rise, the cc gain will reduce, and Cv loop gain increase.
Added after 10 minutes:
cds.linear.com/docs/Datasheet/4062fb.pdf
4062 datasheet.
block diagram in page8.
4062 datasheet.
