http://www.opensourceliberty.org/
related_pg_pin : vdd;
related_pin : "CP";
when : "!E*TE";
fall_power(power_table_27){
values("5.786822e-03, 6.073322e-03",\
"5.551622e-03, 5.914422e-03",\
"5.477922e-03, 5.866422e-03",\
graphene i m working in static and dynamic power annalysis
I want to understand how we have got this table of power !!
and where i can find power_table_27 rca !!
power_lut_template(power_template_7x7) {
variable_1 : input_transition_time ;
variable_2 : total_output_net_capacitance ;
index_1("0.0070965, 0.045852, 0.18189, 0.44168, 0.84642, 1.4143, 2.1616");
index_2("1e-06, 0.00941694, 0.0235424, 0.0470847, 0.0941694, 0.235424, 0.470847");
internal_power() {
related_pin : "A" ;
when : "(B * !(CI))" ;
fall_power(power_template_7x7) {
index_2("0, 0.00941156, 0.0235289, 0.0470578, 0.0941156, 0.235289, 0.470578");
values( \
"0.0146768, 0.0148659, 0.015098, 0.0152821, 0.0154205, 0.015523, 0.0155607", \
"0.0146712, 0.014855, 0.0150864, 0.0152765, 0.0154177, 0.0155122, 0.0155489", \
"0.0145942, 0.0147634, 0.0149767, 0.0151474, 0.0152826, 0.0153727, 0.0154136", \
"0.0143725, 0.0145588, 0.0148401, 0.015037, 0.0151665, 0.0157547, 0.0157996", \
"0.0143294, 0.0144868, 0.0146355, 0.0147795, 0.0149322, 0.0153166, 0.0158676", \
"0.0143482, 0.0144409, 0.0145839, 0.0147435, 0.0149044, 0.015143, 0.0153494", \
"0.0144801, 0.0145109, 0.0146661, 0.0148395, 0.0150029, 0.0150774, 0.0156523" \
i think u need to check somethign claled activity profiling... thats a very subtle yet powerful way to do power analysis.. .
let me be straight to the point.. i think u r wasting your time with lib files for static and dynamic power analysis... i feel unless you design a libray yourself pl dont even bother to understand this....
you will end up wasting your time and eventually end up wrong...
well normal if you look inside the file you should find at the top something like this:
this defined the two axis, and the range of these ones, which is used with:Code:power_lut_template(power_template_7x7) { variable_1 : input_transition_time ; variable_2 : total_output_net_capacitance ; index_1("0.0070965, 0.045852, 0.18189, 0.44168, 0.84642, 1.4143, 2.1616"); index_2("1e-06, 0.00941694, 0.0235424, 0.0470847, 0.0941694, 0.235424, 0.470847"); }
Code:internal_power() { related_pin : "A" ; when : "(B * !(CI))" ; fall_power(power_template_7x7) { index_1("0.0070965, 0.045852, 0.18189, 0.44168, 0.84642, 1.4143, 2.1616"); index_2("0, 0.00941156, 0.0235289, 0.0470578, 0.0941156, 0.235289, 0.470578"); values( \ "0.0146768, 0.0148659, 0.015098, 0.0152821, 0.0154205, 0.015523, 0.0155607", \ "0.0146712, 0.014855, 0.0150864, 0.0152765, 0.0154177, 0.0155122, 0.0155489", \ "0.0145942, 0.0147634, 0.0149767, 0.0151474, 0.0152826, 0.0153727, 0.0154136", \ "0.0143725, 0.0145588, 0.0148401, 0.015037, 0.0151665, 0.0157547, 0.0157996", \ "0.0143294, 0.0144868, 0.0146355, 0.0147795, 0.0149322, 0.0153166, 0.0158676", \ "0.0143482, 0.0144409, 0.0145839, 0.0147435, 0.0149044, 0.015143, 0.0153494", \ "0.0144801, 0.0145109, 0.0146661, 0.0148395, 0.0150029, 0.0150774, 0.0156523" \ ); }
For me, an engineer has curiosity, and that could help to check the liberty is aligned with the timing diagram (more interesting for memories...).
But he need a minimum of intelligent to look inside the liberty if the pattern is used!
