wht will output for this verilog code
shiv_emf
Advanced Member level 2
Given the following verilog code, What value of "a" is displayed ?
always@(clk)begin
a=0;
a<=1;
$display(a);
end
Hello!!!
Cannot use in one always the blocking assignment and nonblocking assignment together!!
a=0 !!!
well ....... I want output nt ur views !!
its posible to write tht code n ... or may b it cant be synthesiable .. but ths nt da issue ..
Wht will be the value of a ......... a=??
Shurik already said the correct answer.
Assuming "a" is a register ...
After each clock edge: a is set to 0, then a is displayed, then a is set to 1.
Remember that a<=1 schedules the assignment for the end of the time step.
For more info, see IEEE Std 1364-2005, section 9.2.2, Example 1.
    shiv_emf
a will display "0" always !!!!
    shiv_emf
