Who Start the Oscillator into Oscillation the First Time?
umery2k75
Advanced Member level 1
Pakistan
If I talk about Hartley,Collpit oscillator,square wave oscillator.In general, it's said feedback must be positive,in phase and the close loop gain must be greater than 1 and there are various feedbacks also in shape of current-series/shunt,voltage series-shunt.Also in some oscillator no input signal is needed to start the oscillator going.Only conditions must be satisfied for self-sustained oscillations to result.
In one book, I read "In practice, close loop gain is made greater than 1 and the system is started oscillating by amplifying noise voltage, which is always present"
In another book, I read " In an oscillator the loop gain AB is greater than 1 when the power is first turned on. A small starting voltage is applied to the input terminals, and the output voltage builds up. After the output voltage reaches a desired level, AB automatically decreases to 1, and the peak-to-peak output becomes constant..........Where does the starting voltage comes from? Every resistor contains some free electrons. Because of the ambient temperature,these free electron move randomly in different directions and generate a noise voltage across the resistor. The motion is so random that it contains frequencies to over 1000 GHz. You can think of each resistor as small ac voltage source producing all frequencies. When you first turn on the power, the only signals in the system are noise voltages generated by the resistors. These noise voltages are amplified and appear at the output terminals. the amplified noise drives the resonant feedback circuit. By deliberate design, we can make the phase shift around the loop equal to 0' at the resonant frequency. Above and below the resonant frequency, the phase shift is different from 0'. In this way, we get oscillation at only one frequency, the resonant frequency of the feedback circuit."
What if I don't have resistors in my oscillator. I don't know if resistors were 1000GHZ frequency generators. Does one have to go into the sub atomic physics to understand who start them into oscillation, as how electrons algins themselves. Or do I attach a high speed camera like oscilloscope to capture the output of the oscillator while turned on in slow motion.
What if my circuit is noise free? I remember there are so many types of noises like white noise,shot noise, nyquist noise.
In the internet,book there is fairly simple explanation of the oscillator in working. Like we might have formula governing them. loop gain,phase equation.Suppose for a wien bridge the notch frequency is fr=1/(2*pi*RC). How does this equation comes from when Mr.Wien design the oscillator. I think this is not the work of Electronic engineer, they must be physicst. The level of details that are present in the electronics books that I have,or the one that I have seen in libraries,stores contains only a certain level of information to get the basic understanding and to calculate some parameters. It never teaches in detail. However, I see there are hundreds of parameter that can be put into the above wien bridge oscillator formula like temperature,pressure, gravity(maybe),etc. Only If I make a complex model of the notch frequency of the Wein Bridge. Oscillators might be crystal clear to a phyicsist but not not as clear to an electronic engineer, who just know how to put things together. For now, I just want to know, you also think of resistors noise as a starter for a oscillator or you also take some another sub-atomic thing in nature and believe this will start the oscillator.
Like in classical phyiscs it was believed a revolving electron must emit electromagnetic radiation and fall into nuclues one day, but it was always getting energy from thermal,etc. I don't know from where but it was that keeping that atom alive. Then Bohr I think proposed the theory of discrete level of electron shells with the help of Spectrum analysis, by the jumping of electrons. We always make an assumtion to saistfy something. I don't know if this concept is an assumption or relaity. Like we say in earlier time about conventional/electronic current flow. Electronics doesn't go into physics level, it is not on low level. Today I am getting irritated by oscillators, I don't know why, please share your views. What you think.
Re: Who Start the Oscillator into Oscillation the First Time
Yes, the oscillator is basically started by thermal noise in the circuit. It's not possible to build a noise-free circuit unless you're operating at absolute zero. And even if you don't define any lumped resistances, your devices and connections will still have some inherent resistance and provide noise.
Not sure what happens if you start talking about superconductors. Would there still be thermal noise?
Regards,
Chris
Is this reality or just an assumption? Do you believe a 1/4W resistor as a 1000Ghz frequency generator? How do I know, how much thermal noise I need to kick start my oscillator??????
xcuse me for the comments....
I try to clear you this one... first of all i am an electronic engineer, but i thing engineering is son of science or say physics so why you had compared both that is useless....
in oscillator no noise or thing is there if you are good electronic engineer you know that there is dc supply or say vdd it is not just vdd continuous when ever you start your circuit initially there is transient and this transient plays roll in generating oscillation as it reflects on output and output is feed back to input....
now still it is not clear try to read more books on transient as well as amplifier... no one has seen electron or proton or neutron but the engineering developed on basis of theory of these elements and due to those theories today you are using this computer, net, cell or any thing
so dear frnd first of all learn to respect physics as well as science
and even though 1000GHz noise is always there in circuit but there is no amplifier circuit to amplify that due to band width limitation and there comes the RF things or microwave theories of say klystron or phyretron or anything...
please dont try to prove wrong the proven physics
- sorry for an undemanding advice from this electronic engineer...
Added after 5 minutes:
just thermal noise cant do any thing it need a transient that provided by vdd dear as I told... and frequency filtering is done by feedback + amplifier circuit as you know bandwidth and filter both very well
I don't understand, if the opener is discussing a real problem or possible lacks of literature. In my opinion, there is no real problem.
@bapodradhairyab
There are hundreds kinds of noise, we are talking about the thermal noise. Not the electrical noise that you are talking about.
Researchers have even invented a single electron transitor. I'm not sure if you are aware of it and single electron has also been captured in video recording. You can find real pictures,video of a single electron captured via a high speed camera .It's a old story.
I'm sorry if I hurt your feeling.
I haven't prove physics wrong. You can review my comment again.
Added after 2 minutes:
How much thermal noise is needed to start the oscillator into oscillation?
What if Vdd is initially at 0V and is very slowly ramped up to normal working voltage? Would the oscillator still start?
Hello umery2k75,
some general remarks to harmonic ("linear") oscillators.
This type of oscillator is interesting as "linear" oscillators must incorporate a certain amount of non-linearity in order to work properly. Sounds a bit contradictory - but it is the truth. Here are some specific points:
1.) Forget about noise. As already mentioned by bapodradhairyab, each oscillator can start as a result of some kind of unsymmetry resp. power switch-on pulse.
2.) Condition for start of oscillation: Loop gain LG real and greater than 1 at one frequency only.
3.) The (ideal) Barkhausen condition (LG=1) is only a necessary one (i.e. not sufficient) and, moreover, can never be realized due to parameter tolerances. Therefore: Design with LG>1 for safe start-up.
4.) There must be a non-linearity which reduces the loop gain with rising amplitudes to a value in the vicinity of LG=1 thereby limiting the signal amplitude before it will be clipped (power rails).
5.) In reality, the value of LG will swing between two values which are slightly above resp. slightly below LG=1 which means: The system poles will swing a bit between two positions slightly left or right to the IM-axis of the s-plane.
6.) In many textbooks. the oscillation condition is not applied and evaluated properly, as the above mentioned condition (Barkhausen) is considered to be also sufficient which is not true.
7.) In your contribution, you have mentioned that the WIEN path is something like a notch. That`s wrong. It is a band pass. The WIEN oscillator was created by Mr. Hewlett and not by Mr. WIEN.
_______________
Perhaps this clarifies something.
Regards
    umery2k75
In simulation, the numerical tolerances can be greater
than input stimuli and startup from extremely low error-
voltage may be suppressed.
A common "cheat" is to kick some sensitive node with a
current pulse. You would like that to bear some relation
to the minimum, expected internal / external noise sources
so that you don't fool yourself about whether it will start
reliably (esp at corners).
Supply dV/dt is a commonly available, real "kick" but some
applications might supply a too-leisurely risetime to trigger an
oscillator that's short on gain, or whose large signal gain at
rest, is less than small signal gain in operation.
You have to challenge the design as meaningfully, from the
applications view, as you can.
Does the world have thermal noise? Yes, I have seen it. I can walk into the lab and in a few minutes of setup I can meausre it. -174 dBm/Hz. In fact, I can measure the amplitude and phase parts of it seperately, with just a little more work. Can I see the startup of oscillations due to that noise floor? Yes indeed, with a little more work I can startup, and then quench and oscillator, and see its frequency spectrum before it has fully reached steady state. And, in fact, it looks like a big blob of amplified noise--shaped by the 3dB bandwidth of the resonator that is attached to the oscillator circuit.
Does the same thermal noise happen at 1000 GHz? I don't know, I don't have a 1000 GHz spectrum analyzer handy to see. I can look at the optical spectrum of a laser circuit, and notice the exact same sort of spectra conditions as I would see in a microwave oscillator. So I can conclude that there is a noise floor up at 1000 GHz too, I just do not know what its level is.
