tiger_ads
Member level 3
3order intercept
can anyone explain 3-order intercept point in spectre simulation??
if frequence1 is 2.45GHz, frequence2 is 2.35GHz, then 1-order harmonic is 2.45GHz, 3-order harmonic is 2.65GHz??
could you explain it in detail??
because 3-order harmonic isn't exclusive, the IIP3 is different, which is the result i need??
thanks a lot!!
Added after 3 minutes:
another question, what factor affect the IIP3, how can i improve it?? eliminate the common source??
thanks
thanks a lot!!
thanks
