Good question. There are, indeed, cases in which "offset" is used instead of "bias".lssdpoly said:
Who can tell me the difference between off-set and bias?
dalraist said:Offset is something unwanted and usually not predictable (due to mismatch, gradients, process variations) which may affect circuit behavior.
drDOC said:Both biasing and offset are unwanted, and both can be stochastic in nature. However we have to live with it.
I cannot see that "biasing is unwanted".
This is incorrect. I have designed lots of amplifiers with transistors in subthreshold and transistors for compensation in linear region. All of these are biased. For some reason people seem to mistake strong inversion with saturation a lot but that's a different issue.In a analog design biasing is required to keep the transistors in design in strong saturation
Wrong. The differential gain will always be the same, you set the output voltage to zero (or mid point for single supply amplifiers). Vout=Adiff(V1-V2+Voff). In that equation Adiff stays constant.bias is the external source that you are applying to op-amp for it to properly operate while the offset is actually used for you to set your differential gain to be zero
