who can tell me how i concretly deal with this code ?
floatgrass
Member level 3
Member level 3
this is a module of my design ,there is memory declaration in it,funtion is correct,now i will syntheze it in order to do timing simulation ,so what do i do with this code and in design analyzer?
thanks ,i am a new asic designer.i need help!
module regfile(
reset_s1,
Write_Mem_q1,
wrapout_s1,
pixel_s1,
Mem_Pointer_s1,
Pix_Mux_s1,
Word_Line_q1[8:0],
Kernel_Bus_b_v1,
pixel_bit0_v1, pixel_bit1_v1, pixel_bit2_v1,
phi1, phi2);
// Port Declarations
input phi1,phi2; // - 2 phase clocks
input reset_s1; // - When reset is high, the counters are
// initialized and when reset is low the
// kernel is loaded and convolution proceeds.
input Write_Mem_q1; // - Read/Write enable for table 1:
// 0 if read, 1 if write.
input [7:0] pixel_s1; // - Pixel input to chip
input [8:0] wrapout_s1; // - control signals from counters.v that
// raises the appropriate wordline.
input [2:0] Mem_Pointer_s1; // - control signal for memory pointer
input [7:0] Pix_Mux_s1; // - selects which bit of the pixel we present
// to the datapath as pixel_bit*
output [8:0] Word_Line_q1; // - SRAM word lines (qualified) are
// passed to DP as possible Kernel_Latch
// clocks.
output [7:0] Kernel_Bus_b_v1;// - 1st Row of SRAM data
output pixel_bit0_v1, // - Bits of pixel values in the 3 rows
pixel_bit1_v1, // of memory, ANDed in datapath with kernel
pixel_bit2_v1; // for multiplication
// Internal Variable Declarations
wire [8:0] wordnum_s1; // - Selects wordlines (address) in memory
reg [23:0] pixelcol_v1; // - Output of SRAM
reg pixtmp0_v1, pixtmp1_v1, // - Output of Pix_Mux (selects bit in pixel)
pixtmp2_v1;
reg pixel_bit0_v1, // - Output of reordering, (mem_pointer)
pixel_bit1_v1, // and pix_mux
pixel_bit2_v1;
//SRAM Variable Declarations
// The following declarations hold the data written to the SRAM during
// initialization.
reg [23:0] memory_v1[8:0];
reg [4:0] decodenum_s1;
wire [23:0] memtemp_v1;
assign wordnum_s1 = wrapout_s1; // Qualification for SRAM is done later
assign Word_Line_q1[0] = wrapout_s1[0] & phi1; // Qualified for kernel latch
assign Word_Line_q1[1] = wrapout_s1[1] & phi1; // Qualified for kernel latch
assign Word_Line_q1[2] = wrapout_s1[2] & phi1; // Qualified for kernel latch
assign Word_Line_q1[3] = wrapout_s1[3] & phi1; // Qualified for kernel latch
assign Word_Line_q1[4] = wrapout_s1[4] & phi1; // Qualified for kernel latch
assign Word_Line_q1[5] = wrapout_s1[5] & phi1; // Qualified for kernel latch
assign Word_Line_q1[6] = wrapout_s1[6] & phi1; // Qualified for kernel latch
assign Word_Line_q1[7] = wrapout_s1[7] & phi1; // Qualified for kernel latch
assign Word_Line_q1[8] = wrapout_s1[8] & phi1; // Qualified for kernel latch
// Convert the wordline selector back to a decimal value so that it may be
// used in an array. This logic is only needed in verilog and won't be
// implemented in layout.
always @(wordnum_s1)
begin
case (wordnum_s1)
9'b000000001: decodenum_s1 = 8;
9'b000000010: decodenum_s1 = 7;
9'b000000100: decodenum_s1 = 6;
9'b000001000: decodenum_s1 = 5;
9'b000010000: decodenum_s1 = 4;
9'b000100000: decodenum_s1 = 3;
9'b001000000: decodenum_s1 = 2;
9'b010000000: decodenum_s1 = 1;
9'b100000000: decodenum_s1 = 0;
// The default case occurs when no wordline is selected.
default: decodenum_s1 = 16;
endcase
end
always @ (phi1 or decodenum_s1 or pixelcol_v1 or Write_Mem_q1)
if (phi1)
begin
// Write pixel values to SRAM
// Note: this line violates strict two-phase clocking
if (Write_Mem_q1 == 1'b1)
begin
memory_v1[decodenum_s1] = pixelcol_v1;
end
end
// Read from SRAM (Base)
assign memtemp_v1 = ~Write_Mem_q1 ? memory_v1[decodenum_s1] : 24'bz;
assign Kernel_Bus_b_v1 = ~memtemp_v1[23:16];
// Route input to appropriate row of memory, we only overwrite the
// row which Mem_Pointer tells us is the oldest. (This doesn't
// model layout exactly, but the idea is the same) ie: in layout
// because all rows except the one being written to have a high
// impedance input, they retain their old value.
// Include Pix_Mux_s1 in sensitivity list to load pixelcol_v1 just
// before every write to mem, regardless if pixel_s1 or
// Mem_Pointer_s1 has changed or not.
always @ (Mem_Pointer_s1 or pixel_s1 or Pix_Mux_s1)
begin
if (Pix_Mux_s1[7])
begin
case (Mem_Pointer_s1)
3'b001: begin
pixelcol_v1[23:16] = pixel_s1;
pixelcol_v1[15:8] = memtemp_v1[15:8];
pixelcol_v1[7:0] = memtemp_v1[7:0];
end
3'b010: begin
pixelcol_v1[23:16] = memtemp_v1[23:16];
pixelcol_v1[15:8] = pixel_s1;
end
3'b100: begin
pixelcol_v1[7:0] = pixel_s1;
end
default: pixelcol_v1 = memtemp_v1; // nothing new is written
endcase
end
end
// Mux the output, so we recover only one bit per row on a read
always @ (Pix_Mux_s1 or memtemp_v1)
begin
case (Pix_Mux_s1)
8'b00000001: begin
pixtmp0_v1 = memtemp_v1[16];
pixtmp1_v1 = memtemp_v1[8];
pixtmp2_v1 = memtemp_v1[0];
end
8'b00000010: begin
pixtmp0_v1 = memtemp_v1[17];
pixtmp1_v1 = memtemp_v1[9];
pixtmp2_v1 = memtemp_v1[1];
end
8'b00000100: begin
pixtmp0_v1 = memtemp_v1[18];
pixtmp1_v1 = memtemp_v1[10];
pixtmp2_v1 = memtemp_v1[2];
end
8'b00001000: begin
pixtmp0_v1 = memtemp_v1[19];
pixtmp1_v1 = memtemp_v1[11];
pixtmp2_v1 = memtemp_v1[3];
end
8'b00010000: begin
pixtmp0_v1 = memtemp_v1[20];
pixtmp1_v1 = memtemp_v1[12];
pixtmp2_v1 = memtemp_v1[4];
end
8'b00100000: begin
pixtmp0_v1 = memtemp_v1[21];
pixtmp1_v1 = memtemp_v1[13];
pixtmp2_v1 = memtemp_v1[5];
end
8'b01000000: begin
pixtmp0_v1 = memtemp_v1[22];
pixtmp1_v1 = memtemp_v1[14];
pixtmp2_v1 = memtemp_v1[6];
end
8'b10000000: begin
pixtmp0_v1 = memtemp_v1[23];
pixtmp1_v1 = memtemp_v1[15];
pixtmp2_v1 = memtemp_v1[7];
end
default: begin
pixtmp0_v1 = 1'bz;
pixtmp1_v1 = 1'bz;
pixtmp2_v1 = 1'bz;
end
endcase
end
// Sort the temporary pixel bits so that the rows are re-ordered
// based on the value of the memory pointer
always @ (Mem_Pointer_s1 or pixtmp0_v1 or pixtmp1_v1 or pixtmp2_v1)
begin
3'b001: begin
pixel_bit0_v1 = pixtmp0_v1; // Normal ordering.
pixel_bit1_v1 = pixtmp1_v1;
pixel_bit2_v1 = pixtmp2_v1;
end
3'b010: begin
pixel_bit0_v1 = pixtmp1_v1; // 2nd row filled.
pixel_bit1_v1 = pixtmp2_v1;
pixel_bit2_v1 = pixtmp0_v1;
end
3'b100: begin
pixel_bit0_v1 = pixtmp2_v1; // 3rd row filled.
pixel_bit1_v1 = pixtmp0_v1;
pixel_bit2_v1 = pixtmp1_v1;
end
default: begin
pixel_bit0_v1 = 1'bz;
pixel_bit1_v1 = 1'bz;
pixel_bit2_v1 = 1'bz;
end
endcase
end
// Note: This is ordering is fine for now, but on the bigger picture,
// it is confusing to visualize. It would be clearer if pixel_bit0
// corresponded to the bottom row of the kernel, pixel_bit1 to the
// middle, and pixel_bit2 to the top. Then we could imagine we
// were feeding in values in the bottom row of the image, and
// those values then got shifted up.
// End of SRAM Memory
endmodule // memory
seems reg [23:0] memory_v1[8:0]; is the sram you mention.
acutally if you synthesize this code, dc will make it a lot of regstiers.
for sram you should use module call
and you need sram models provide by library vendor for simulation, sram is just a cell like dff in library.
yes, I mean reg [23:0] memory_v1[8:0] is the sram.
you mean this code can not be synthesize by dc, but this code has one 8 to 1 mux and 3 to 1mux besides the sram.
if I don't synthesize it, mux logic can not be mapped and optimized.
it has not sdf in mux. i can not deal the timing simulation.
you can synthesize it.
but this code is not ok.
you should delete the sram part
and replace it with the module call to the sram lib.
the mux should be kept.
the module of call sram lib look something like this
sram_16_8 ram0(
.addr(addr),
.clk(clk),
.din(w_d[7:0]),
.dout(r_d[7:0]),
.ena(cs),
.web(w) );
sram_16_8 is a lib module
bests
you mean I replace the sram with module call of sram .v library. but design compiler use sram .db library to compile ,how do I set it in dc?
thanks
Try memory compiler, it can generate layout, simulation model and necessary file for MBIST, if you really need SRAM. Otherwise, register file is enough for this size of memory. Any other opinion !
do not compile RAM
Hi, do not try to compile RAM with synthesis tools, since it's unefficient. Try to use memory compile provided by your vendor, or you have to do custom circuit design.
