RachelAnne
Newbie
The pressure bridge on my left is a pressure sensor with four pins (1: NC. 2: Vsupply. 3: OUTPUT+. 4: GND). Pin 1 is floating, pin 2 is connected to 5V voltage, and pin 3 is connected to AD623 3 Pin (+In), pin 4 is grounded.
Pin 2 (-In) and pin 4 (-Vs) of my AD623 are grounded, pin 7 (+Vs) is connected to the 5V voltage, pin 5 reaches the 0.4V voltage as shown in the figure, and pins 1 and 8 are connected to a 100 ohm potentiometer. Now the measured voltage of pin 3 is about 0.508V, but the output of pin 6 is always only about 0.023V. Later, when pins 1 and 8 were opened, the gain was changed to 1, but the output was still about 0.02V.
Reference:
Reference:
AD623 Instrumentation Amplifier: Pinout, Circuit and AlternativesHello, everybody! I welcome you on board. I am glad to see you around. In this post today, I’ll walk you through the Introduction to AD623. AD623 is a single and dual supply, rail-to-rail, low cost instrumentation amplifier. I suggest you buckle up since I’ll introduce the complete Introduction...
www.utmel.com
