" Vim syntax file
" Language: Spectre circuit simulator input netlist
" Maintainer: Ahmed Nabil "anabil@ieee.org"
" Last Change: 29/04/2002
" Comments: Spectre is an advanced circuit simulator from Cadence Design Systems
" that simulates analog and digital circuits at the differential equation level.
" This is based on spice.vim by Noam Halevy
" For version 5.x: Clear all syntax items
" For version 6.x: Quit when a syntax file was already loaded
if version < 600
syntax clear
elseif exists("b:current_syntax")
finish
endif
" spectre syntax is case INsensitive
syn case ignore
syn keyword spectreTodo contained TODO
syn keyword spectreStatement ac alter check dc envlp info montecarlo noise options pac pdisto pnoise psp pss pxf
syn keyword spectreStatement qpac qpnoise qpss qpxf set shell sp sweep tdr tran xf
syn keyword spectreStatement include section simulatorOptions modelParameter element outputParameter saveOptions simultor
syn keyword spectreStatement abs acos acosh altergroup asin asinh atan atan2 atanh ceil correlate cos cosh else end
syn keyword spectreStatement ends exp export floor fmod for function global hypot ic if inline int library local log
syn keyword spectreStatement log10 march max min model nodeset parameters paramset plot pow print pwr real return
syn keyword spectreStatement save sens simulator sin sinh sqrt statistics subckt tan tanh to truncate vary
" Numbers, all with engineering suffixes and optional units
"floating point number, with dot, optional exponent
syn match spectreNumber "\<[0-9]\+\.[0-9]*\(e[-+]\=[0-9]\+\)\=\(meg\=\|[afpnumkg]\)\="
"floating point number, starting with a dot, optional exponent
syn match spectreNumber "\.[0-9]\+\(e[-+]\=[0-9]\+\)\=\(meg\=\|[afpnumkg]\)\="
"integer number with optional exponent
syn match spectreNumber "\<[0-9]\+\(e[-+]\=[0-9]\+\)\=\(meg\=\|[afpnumkg]\)\="
" Misc
syn match spectreWrapLineOperator "\\$"
syn match spectreWrapLineOperator "^+"
syn match spectreIgnore "\ \ \ "
syn match spectreStatement "^ \=\.\I\+"
syn region spectreString start=+L\="+ skip=+\\\\\|\\"+ end=+"+
syn region spectreComment start="//" end="$" contains=spectreTodo
" Matching pairs of parentheses
syn region spectreParen transparent matchgroup=spectreOperator start="(" end=")" contains=ALLBUT,spectreParenError
syn region spectreSinglequote matchgroup=spectreOperator start=+'+ end=+'+ oneline
"syn match spectreKeyword /)\ \<[a-z]\+[0-9]*[a-z]*\>\ /
" Errors
syn match spectreParenError ")"
" Syncs
syn sync minlines=50
" Define the default highlighting.
" For version 5.7 and earlier: only when not done already
" For version 5.8 and later: only when an item doesn't have highlighting yet
if version >= 508 || !exists("did_spectre_syntax_inits")
if version < 508
let did_spectre_syntax_inits = 1
command -nargs=+ HiLink hi link <args>
else
command -nargs=+ HiLink hi def link <args>
endif
HiLink spectreTodo Todo
HiLink spectreWrapLineOperator spectreOperator
HiLink spectreSinglequote spectreExpr
HiLink spectreExpr Function
HiLink spectreParenError Error
HiLink spectreStatement Statement
HiLink spectreNumber Number
HiLink spectreComment Comment
HiLink spectreOperator Operator
HiLink spectreString String
HiLink spectreKeyword Type
HiLink spectreIgnore Ignore
delcommand HiLink
endif
let b:current_syntax = "spectre"
" insert the following to $VIM/syntax/scripts.vim
" to autodetect HSpice netlists and text listing output:
" " Spice netlists and text listings
" elseif getline(1) =~ 'spectre\>' || getline("$") =~ '^\.end'
" so <sfile>:h/spectre.vim
