White LED drive circuit
vicky.pace
Member level 1
Member level 1
white led circuit
Hellow.
I need to have an exilent circuit to drive white LED from 6V or 12V battery. Application can be varried from one LED to 100 LEDs.
Please help.
Regards
Vicky
led drive circuit
Add a resistor in series with each LED being connected to the battery.
white led driver circuit
vicky.pace said:
Hellow.
Please help.
Regards
Vicky
What is your LED rating?
white led circuits
you have many leds...so best you put in series and regualte the current in the string using a led driver...
you can use boost led driver......surt on linear.com etc etc and others for led drivers....or you can make one yourse;lf out of a uc3845 uc3842.
its just a @current catcher"...current gets to threshold ..turn off
all the led drivers on web are SMD...if you want thru hole you have to use say uc3845 like i say.
you must drive leds current mode.......must
it too inefficent to do voltage mode....you done want ANY resistor s in series......you r batt muss be preserved
led driver circuit
Take a look at:
There are a few example drivers.
