Which would be the simplest way to detect a FAN locked in PC
Basil
Member level 5
Member level 5
Locked FAN detection
:?: Which would be the simplest way to detect a FAN locked in a PC?. Fan provides an status on/off signal.
most of PC fans have pulse open collector output (central pin in fan connector), many monitoring programs can detect rotation failure
Re: Locked FAN detection
I've seen it. Do you know which is the electric interfase?
What do you mean "electric interfase" ?
I mean
1) voltage levels
2) pinout (if it's standarized. I'm no sure central cable is sensor output, my fan has a central black wire and yellor and red on the sides... I'd bet red=+12VDC, and black=0VDC)
and I'd add logic (open colector?, normal = HI?)
Yes, usually sensor wire is yellow, but better check it with meter
It is open collector output from internal magnetic HALL sensors, giving 1 or more negative pulses per revolution.
Apologies, if it;s obvious. But usually, the fans have a part number and manufacturer written on the rotor. You can look up the datasheet for the fan and find everything about the sensor output in it.
pin 2 {usualy a yellow or white wire}
gives on off once or more per rotation
you can monitor it using a scope ...
