aj_silverthunder
Full Member level 3
here in this schematic,as many said,the RFC value would be 1mH,1uH,100uH.
which one would u select!
and also tell me what if i use the higher value choke and what if i use low value RF Choke!what will be the result !
if the value of the RF choke is not correct would the circuit components get burned or will there be no clarity in the output of the transmitter!
