Which Transistor in this list is simplest for learn the biasing and use as a switch?
rozeh
Junior Member level 1
Hello everybody:)
In this list, which transistor is simplest for learn the biasing and learn to use of a transistor as a switch?
  1. C945
  2. BC327
  3. MJE13001
  4. 2N2222
  5. 2SC1815
  6. BC547
  7. A733
  8. BC547
  9. BC556
  10. 2N5401
  11. 2N5551
  12. 2SA1015
  13. 2SC8550
  14. BC307
  15. BC337
I'm a beginner and I want to learn all thing about a transistor.;-)
The 2N2222 has been around forever and can be considered something of a "standard". Really, any general purpose transistor is a good starting point as long as you have a decent data sheet to get all the parameters you'll need for your calculations.
Reactions: rozeh
    rozeh
I expect they are all about equally "simple" to learn. It just depends upon what current and voltage you want to switch.
Reactions: rozeh
    rozeh
Thanks guys,
Well when I saw in alldatasheet.com(for 2N2222) for seeing the datasheet. the 2n2222 transistor has many type. what's the difference between these types:
  • NPN switching transistors
  • HIGH-SPEED SWITCHES
  • Chip Type 2C2222A Geometry 0400 Polarity NPN
  • NPN Silicon Planar Transistors
  • NPN Small Signal General Purpose Amplifiers
  • and so on...
Which is suitable for learning? Why does it has many types?
0-5volt
Those aren't different types of 2N2222. They're just different descriptions of the 2N2222 and it's uses.
For example:
A 2N2222 can be used for switching.
A 2N2222 can be used for high speed switching.
A 2N2222 can be used for small signal amplification.
A 2N2222 can be used for general purpose amplification.
A 2N2222 is an NPN silicon transistor.
A 2N2222 is a silicon planar epitaxial transistor.
Reactions: rozeh
    rozeh
I would say the 2N3904 its not on your list but if talking about it for the purpose of learn I'd go for something that is going to be cheap to replace if say it burns out.
Reactions: rozeh
    rozeh
For example:
but if you see the datasheets of those types, you'd know that they mentioned those titles in it's datasheets.:roll:
You answered half my question. ;-)
Oh, sorry
For a simple battery. I think 1.5A is suitable.:wink:
Yes, but they are all describing the same transistor.
Oh, sorry
The you need to look through your list for a transistor that has a voltage rate of at least 7V and a current rating of at least 2A. The 2N2222, for example, is only good for a maximum of 800mA.
Actually for switching that amount of current a MOSFET may be a better choice since they require no steady-stage gate current to turn ON. A BJT requires the base current be about 10% of the collector current to be fully ON.
Reactions: rozeh
    rozeh
Ok
Probably I can solve this problem by a voltage divider. What's your opinion?
Thanks, I have seen the datasheets.
I you bothered to read more than just the titles, you may start to get the point.
Nope, that won't work.
If this is just for learning and experimenting, why not just get a cheap low power transistor, and use it within it's limits.
Reactions: rozeh
    rozeh
What is your suggestion for my range?(0-5v and 1.5A)
My suggestion was to change your range. Instead of trying to switch 1.5A, why not start with 10mA or 100mA? Then you can use an inexpensive transistor.
In post 1, you said you want to learn about biasing and learn about how to use a transistor as a switch, so it sounds like you don't have a particular project in mind.
Reactions: rozeh
    rozeh
Since you state this is for learning, then you should learn to read data sheets and go through your list to find ones that may meet your voltage and current requirements. That's what we would have to do. If you can't read data sheets then you won't get far in learning how to build electronic circuits.
Reactions: rozeh
    rozeh
Yes, but 10-100mA is low. my problem is supply. I would like to supply the transistor by a battry. I thought I can solve the problem of supply by a voltage divider but you said to me that that won't work.:-( How can I solve the problem of supply?
Where can I find the full explanation about all thing in a transistor datasheet?
Exactly! I am suggesting you use low current.
If your circuit draws a low current, the battery will last a longer time.
If your circuit draws a high current, the battery will go flat quicker.
There is no problem.
Why do you think high current is needed for a battery-powered circuit?
Reactions: rozeh
    rozeh
Then, please suggest me a good transistor for that range that you mentioned.
2n3904 and 2n2222 are popular transistors, they are cheap and widely available. Many hobbyists design their circuits around these. I suggest you get some of these and assemble some simple LED flasher circuits, to understand and explore how a transistor works.
Reactions: rozeh
    rozeh
