Which tool can draw plain text waveform like X____X__X__X
sweesw
Member level 2
Member level 2
plain waveform
Is that possilbe to automatically draw logic waveform like the following:
____________/\________________/\_________
draw waveforms in php
timing designer is a powerful tool for drawing waveforms, but in graphical mode. You can draw any required wavefor using just MS word, and it's tables. you can develope some set of templates and copy paste them whenever required. the result will be beautiful and easy to understand.
text waveform
Is it possible to covert timing designer waveform into plain text format like what I draw above?
I need to incorporate the text waveform into my Verilog HDL source code for documentation purpose.
input timing file
It depends on the format of the input timing file
Re: Which tool can draw plain text waveform like X____X__X__
There is tool that does exactly the opposite (if you are interested!)
It is called ANDYTIME, is pretty handy for simple tasks and you get to draw the timing diagram in ASCII.
Cheers mates
the_penetrator©
Signal Scan from Cadence in stand alone mode is use ful.
I don't know any tool but you can do:
-From your testbench or simulator, dump your signals in a vcd file.
-Parse the VCD file and generate the waveform with your own Perl script.
You should be able to do it (Perl script) in a couple of hours.
regards
fe
Cheers mates
the_penetrator©
Here is ANDYTIME, a m$-windows app.
