vbhupendra
Full Member level 4
- Joined
- May 11, 2005
- Messages
- 235
- Helped
- 15
- Reputation
- 30
- Reaction score
- 10
- Trophy points
- 1,298
- Location
- GOA, INDIA
- Activity points
- 3,219
i need to find out the foundary and technology which supports upto 40V i/o, transistors. The requirement is following :
1. PCB to ASIC
2.Analog circuit
3.Input Pin Voltage –30 V AC Max
4.Input Pin Current- 2A
5.Output is a pulse which triggers magnetic leverset and reset coil.
Pls let me know which technology and foundary should i use in this application ?
i did found xfab has 0.8u technology for industrial applications but i am not able to find whether it has 40V I/O Library ?
Thanks
1. PCB to ASIC
2.Analog circuit
Thanks
