cupoftea
Advanced Member level 5
Googling this just reveals the standards for transient overvoltages.
Do you know which EN standard deals with the smps output overvoltages which happen when the feedback loop components go open circuit?
(pertaining to offline isolated SMPSs).
You would think output overvoltage detection would need
to result in latched shutdown, since if hiccupping, and on
no-load, then every hiccup_ON poors a bit more charge into the output
caps and they go higher and higher in voltage...as such danger ensues.
..so which standard tells that Latched shutdown is needed in case of feedback loop open circuit?...(which results
obviously in output overvoltage)
