Which software is good for PCB design for embedded systems and microcontrollers?
thisistausif
Member level 2
Member level 2
india
hello
which softawe is good for pcb design for embedded systems and microcontroller based applications
which is good ?
i tested orcad and altium designer.
both of them are good. but there is 2 important parameter for you to chose asoftware .
1- how you will make your PCB. and which software is better for that way." in my country using protel or altium designer is more easiar than orcad caz there are a lot of companies which work with protel and manufactor PCB's"
2- how easily you can use the software. and the reliblity of the results.
"i couldn't work very easily with orcad and at the end i found a lot of errors in the final file."
so i think altumdesigner is better than orcad." i don't check the orcad 15.7"
which is good ?
Hi
Which processor or controller U want to use ? For 51 core Keil is the best
which is good ?
i am working with msp430
is there any all in one pcb design circuit simulation
Re: which is good ?
PAds from mentor graphic
mehdi
Re: which is good ?
How about Proteus? I like it a lot!
Re: which is good ?
Re: which is good ?
Allegro ,Pads and cadstar windows verion are very much user friendly.
