tony_lth
Advanced Member level 5
![Advanced Member level 5](/styles/images/ranks/hlevel2.gif)
Hi, Gurus,
I need to design a microstrip antenna for 60GHz mmwave.
And the area is limited to 6mm*6mm, not including the matching subs.
So which type has the maximum gain? Antenna Array is also ok, only the total area is limited to the aforesaid.
I design a simple square antenna, which has 4.5dB at 60GHz.
I know there should be some type or pattern antenna has the more gain.
I just want to the pattern, so that I can build the model to further optimizing.
Sincerely,
Tony Liu
Sincerely,
Tony Liu
