Hey Dude!
Hi
Non of them are not LDO. And about compensation circuit: I think its place is between the out put of op amp and its inverting input.
Best wishes
Goldsmith
What is "IPROBE"? And what is actually in the compensation network? How are you measuring loop response? The feedback path is split, so it really matters. It's hard to tell what's going on what's going on with such a vague diagram.
Your circuits are topologically different in the compensation so why do
you expect identical response?
I'm not a real big fan of stb. When everything is right it's a handy shortcut.
But determining -whether- things are right, is still easier for me using AC
analysis and transient. Get the circuit working without the iprobe and
then figure out where to insert it.
I much prefer looking at step response for rough stability tweaking.
Once it looks critically damped then I go about proving the phase /
gain margins. LDOs are only small signal when things are sitting still.
The interesting challenge is a near-full-scale load step.
